My girlfriend has a Clio Dymanique + 1.4 16V which she has had for over a year now. It has only been to the garage once to have its 6monthly safety check. It recently went into the garage for a Renault recall to have the throttle body replaced (has anyone else had this done ?) since this replacement every so often (seems to be random) the engine management light will light up and then immediately after the engine will rev to approx 2k constantly until you turn the engine off, when you start it back up again everything is normal again ... until the next time it happens.
Now its been into the garage 6 times now, the fault has occured 8times but obviously when they do a test drive its ok.
My question is has anyone else experienced a problem like this ? I keep suggestto the garage why dont they swap the throttle body but they just seem to reset the computer. Today it is back in and they have eventually ordered a part for it, but its not the throttle body, is something else to do with the throttle pedal (which could be the probem I know!)
