New member need advice on spacers sorry
  318i e46, 323ti e36
hi first post sorry about the subject I know it's been done to death but I've trawled through and not found my answer. Anyway I'm running 15 inch alloys et38 and lowered by 60mm on spax springs I'm planning to get spacers 25mm front 20 rear. Wondering if anyone has done this or knows if i will get any rubbing
thanks
  Clio 2.0 16v 182
Haven't measured that but it should be fine. The top won't rub but be careful when turning. Front spacers larger than 25mm may cause rub depending on your camber and offset.
  318i e46, 323ti e36
Thanks for your help as I say the wheels are et 38 offset and I haven't done anything with camber (yet). When I measured the gap from arch to tyre, it seemed I had about 30mm all round but I wasn't sure whether this was a good enough gauge on whether the wheels would rub.
  318i e46, 323ti e36
I mean by measuring vertically down from the outside of the arch and then horizontal from the widest point on the tyre. My previous reply seemed tricky to understand
  318i e46, 323ti e36
They are here should be getting them fitted Thursday and will post results
