New System
ok ive just brought 2 sets of Infinity 5002i speakers and a Alpine R type sub i already have an Alpine headunit fitted.
so i was just wondering if u guys could suggest a good amp 2 power the sub around 800watt but below £150 if possible?
also will this system b a good set up?
thanks
will either one of these amps b ok to power just my sub?
Legacy LA 570 -
800W 2 channel amplifier
2 x 400W or 1 x 800W
Remote control bass boost
Fully adjustable electronic crossover network
2 ohm stereo stable bridgeable into 4 ohms
MOSFET PWM power supplies
Variable gain control
Remote turn on/off
or
Sony XM 2165GTX -
1000W 2 channel amplifier
Stereo or bridged mono output
4-ohm stablein bridged mode
Tri-Way capable
MOSFET power supply and outputstages
Gold-plated connectors
Variable bass boost
  Polo + Micra
you could do but you may have to put a voice coil per channel (which is never a good idea)
it also means you will not get the full power out of the amp
just did a bit of research and that legacy is a f**king joke it only does 2x 85wRMS at 2 ohms
[Edited by Dink on 1/8/2005 1:33:59 PM]
[Edited by Dink on 1/8/2005 1:46:28 PM]
  Polo + Micra
the sony will do 400wRMS into 4 0hms(a dvc sub with 2 ohm voice coils)
or 330wRMS into a dvc sub with 4 ohm voice coils with a voice coil per channel
