New Yozza Exhaust - Help with fitting/question?
DB.
  BMW 440i
Hi, Just bought a new Yozza Exhaust system and will be fitting when i get back from Nottingham.
Just wondering if i should replace the mounts, which mounts, and where to get them from if i should. Its an 05 plate on 37k.
Not to knowledgeable on the 182s yet so any help appreciated, ive tried a search and cant seem to make much sense of what i have found.
Thanks,
Dave
The Boosh!
ClioSport Admin
  Elise, Duster
If your old mounts are fooked then your std zorst will be saggy than your grandads balls so you will know.
I never replaced mine when I fitted it :)
  Golf GTD Mk7
you have to remember the old system is heavier, so the mounts will have been stretched slightly. Mine were quite old when I put my BTB on, but still ok. put it on and see how they are. You can always change them after it's fitted. May as well save some money if you can. credit crunch ftw :(
Jamie
It's obvious if they're worn. Have a look at how many hairline cracks are in them. No point in having a off middle exhaust.
Da
  Less
My mounts were knackered courtesy of the Magnex I had on previously ;)
I'm sure that was heavier than the OE exhaust!
DB.
  BMW 440i
Ok then, well it will most likely be going to Fred to get fitted so we will just have to see i suppose!
Thanks for the help!
