Newbie questions!
Car  Arctic 182, GTD
Just bought a 182 today and got a few questions regarding it...
First, it was running low on fuel when I bought it, so I filled it up with shell V power and then the engine management light came on? But still runs fine?? And also if I'm giving the car a little bit of throttle, sometimes the handbrake light and the STOP light flicker?? And lastly if I let off in third sometimes it trys to knock it out of gear, is this the dogbone engine mount??
Thanks in advance!!
Regarding the car going out of gear, it is due to a warn / moving engine mount(s), yep normally it's the dog bone mount.
Regarding the other stuff, I don't really know the answer but someone else will as I'm sure I've seen something like this mentioned on here before (try the forum search). Regarding the fuel, I think it must just be a coincidence, unless perhaps it has been running on 95 for a long long time and is also mapped to 95 (not standard) - just a guess.
well I found out tonight the reason for the handbrake light and stop light is because was running low on brake fluid. and the engine management one is still a mystery :\ lol getting the dogbone powerflexed because the bushes are like £15 from work :) I take it you mean 95 RON fuel yeah?? wel I'm only gonna run it on Vpower from now best stuff in my opinion and you get more MPG.
