Newbie to Clio Forum Any help appreciated
  Clio Sport -VR6golf
Hi - long story and long shot for help - but driving Son's 2004 Clio Sport 2.0 16V to keep going as he is abroad.
Engine lights came on and AA diagnosed faulty alternator. Drove absolutely fine to garage on residue in battery (not far away) left at garage for Alternator and belt to be changed. Went to collect car from garage and would not start! Garage now telling me no pressure in Cylinder 1 and quoted £1500 repair bill and have left the car engine stripped and have basically said I cannot prove it was them that caused the issue and accept no responsibility. I believe they may have run the car for a long period whereby the Oil / Water pump wasn't working and "cooked" the cylinder as engine got too hot, but obviously wasn't there so can't prove. Have had car flat-bedded to another garage and they confirm cylinder problem and fixable but would be expensive because of time that would be involved..
1) any ideas how the damage may have occurred apart from above?
2) anybody had a similar experience and what was outcome?
3) looking now to sell but breaks my heart to sell for £300 scrap
Cheers guys
Mr Trailer Man
Only thing i can think of is the belt has been fitted wrong or not tensioned correctly and has slipped off into the cambelt (this is common).
That causes the timing belt to slip and valves get bent.
Get the timing checked with the correct tools if possible, if it's massively out then there's your proof.
Edit: I see you mentioned the engine is stripped? Did you agree to them doing that and are there any bent valves?
  Clio Sport -VR6golf
Hi thank you for your help. It was supposed to be only the alternator belt that was changed and they were not to touch the timing belt as I was aware that this needs careful and specific setting up. I would have to try to get a mobile engineer to check the timing, as car currently stuck in my garage and I am not that mechanically able LOL! Garage actually left it stripped as they said "it would assist repair and save time"!!! they actually pushed the car out of their garage and all the way into mine, to free up the space in their workshop. TBH I think they wanted it as far away ASAP. I don't know if any valves are bent - this wasn't on the report from the alternative garage, so I am hoping not. Thank you for your time.
  Clio 182 Sport
I would have expected them to call me and ask before carrying out any work other than replacing the alternator belt. If you can prove you drove to the garage I would ask when they became aware of the issue? How did they get it into their workshop?
davo172
  TCR'd 172
I would also say this is what has happened they have stripped it to look and thought oh f**k!
Mr Squashie
CSF Harvester
  Clio 182
I can't believe the garage are claiming it's not their responsibility when you dropped off a functioning car and they've handed you back a dead one!
Mr Trailer Man
I didn't mean they touched the timing belt.
I'm thinking the aux belt has jumped off the pulley and into the timing belt, causing the timing to slip.
  Clio 182 Sport
Whilst it can be a bit of a hassle, I would consider taking them to small claims court. I did this a few years back and also had an engineer inspect my car and write a report. It cost about £300 I think, but was awarded in costs when I won my case. That said, with the joys of online reviews, most garages know that a well worded Trust Pilot review can cause them problems when they try and have someone over. Have you looked to see if the garage has any other poor reviews?
Darren S
Customer - car is broken
Garage - HULK SMASH!
Customer - but my car is still broken. And is now in pieces.
Garage - meh.
Don't scrap it - but as others, external support like citizens advice or trading standards should be involved here. The garage's actions have proven to be ridiculous.
  Clio Sport -VR6golf
Thanks that's brilliant - Yes, possibility! I am ringing round trying to see if somebody could check the timing in the state that the car is in at present. If this is the problem, then the garage have clearly caused the issue themselves whilst working on changing the alternator. The belts are close(ish) together, so may have slipped. Everything crossed I can find a reliable mobile engineer. Cheers again.
Mr Trailer Man
What state of disassembly is the engine currently in?
  Clio Sport -VR6golf
They carried out the Alternator change and alternator belt change as per my ask, but never called for permission to do anything else. As it didn't start once they had done the alternator, I think they tried to fix and found problem larger than they anticipated and that is what I walked into when I went to pick up the car. In bits and broken. I drive it the the garage OK and left on their forecourt, so I presume they drove it into their workshop (can't prove as I was not there when they moved it)
  Clio Sport -VR6golf
Garage - meh.
I def think I will have to go down CA route or small claims if I can't get a mobile engineer to get timing checked. Can't bear to have it scrapped because of the garage's (bleep) up.
  Clio Sport -VR6golf
Absolutely an option and will check out CA too for advice - Have called Legal at AA and they say garage "has a duty of care" whilst in their possession and to start a claim. Real hassle but, if it saves the Clio all worth it. I have asked about and word of mouth is not always good! wish I had known before!!
R3k1355
They've fucked it up and ruined the engine.
The chances that a perfectly running car drives into the garage for an alternator fault and magically eats Cylinder number 1 on it's own accord are super small.
  Clio Sport -VR6golf
I know, nor can I, but they said I can't prove they damaged it!!!!! I think the phrase they used was "These things happen and this is a coincidence" !
R3k1355
Where are you located?
There's a few good specialists around, it might be worth having it trailered to them for an inspection and report.
  Clio Sport -VR6golf
Absolutely my gut feeling too! No indication of anything wrong with engine when running on the drive to the garage. Must try and get sorted for Son's sake - he is gutted with being away and unable to deal.
R3k1355
Small things can break, snap or just disintegrate when doing a job. Things like electrical connectors, clips, bits of trim and such.
Those things can happen.
Not losing an entire cylinder, especially when the job they were doing has nothing to do with that part of the engine.
  Clio Sport -VR6golf
I am ringing around to try to get timing checked if poss - based 20 mins or so out of Cambridge.
R3k1355
Two techs down in Dartford are pretty good.
Also Mick @ Diamond is excellent
Darren S
That said - the Renault dealership that I took mine too for its alternator replacement - took three attempts to get it right. :rolleyes:
R3k1355
Did it leave on a flatbed tho?
That's the difference you pay for when you go to a main dealer.
  Clio Sport -VR6golf
Appreciate the suggestions but bit too far away unfortunately. Will persevere and try my (non-luck) nearer to home. Thanks
  Clio Sport -VR6golf
Pics - sad eh!
  Clio Sport -VR6golf
Thank you so much. Will contact him tomorrow - much appreciated.
Hi
Just want to thank all in this thread for their suggestions and help. Special shout out to James Bryan - the recommendation to get in touch with Chris at Beaniesport in Bedford 07834 692507 was a godsend. Thank you. Chris went overboard to help and even came to see the car in situ, with his toolbox, in the rain and confirmed your earlier suggestion that the garage had not checked the timing as this was way out! and also found that the new aux belt was not properly seated and rubbing on the tension spring too. Chris went over and above explaining and offering assistance with this problem - only wish I had heard of him before!!! Looks like it is the original garages fault and I now have evidence to prove it. Car is fixable at a cost and will try to get that cost covered from them (a fight I expect, but worth the effort to be sure).
You guys are Stars and thanks for the info. Fingers crossed for a happy result.
  Clio 182 Sport
Really pleased for you. It's never nice having to confront issues like this, where fault lies with supposed professionals. Especially where potential County Court action is called for. Hopefully though, once the issue is pointed out and the evidence shown, they'll realise their mistake and help remedy the situation. Best of luck with getting things sorted. Mark
imprezaworks
  Mk5 Golf GTI :)
Yeah I wouldn't be taking it back there. I would get it fixed electric and claim costs back
Mr Trailer Man
Hi
No problem, glad to hear he was able to help.
I'm guessing you'll be getting Chris to repair it for you if you can recover the costs from the previous garage?
Clio_fool
Make sure you do things properly from here on. I doubt the garage will be helpful when they see the cost of repair from elsewhere.
R3k1355
That's excellent service from Beaniesport. They sound like your go-to company.
100% the original garage will stonewall you, they won't want to admit their mistakes and won't want to pay for someone to make it right.
Be prepared for the legal route, you'll win but not quickly.
