Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
My cup has failed MOT due to rear brakes, thought it wads seized caliper but upon replacing that still nothing, I don't believe there is any fluid getting to it. Just replaced lines and handbrKe cables also ? Any ideas ?
You could disconnect the n/s rear hose, front passenger side of the rear beam and see if it leaks any fluid. Might help in diagnosing where along the system the problem is, as if fluids getting to there, it stands to reason that it's some of the pipe work on the rear beam at fault if the caliper is fine.
