No sound from rear speakers
  Clio dynamique 1.4 16v
I replaced the factory HU at the weekend with my alpine, everything is fine memory wise. the prob is there is no sound from the rear speakers. Any ideas?
Cookie
Go through the menus on the headunit and check the balance, might be pushed all the way to the front by default or something silly.
  Renault Clio, 216 Tomcat
check the wiring at the rear and trace it all the way along. by pulling on the harness u may have dislodged wires mate.. eaither that or they r f**ked mate. if they are i can send u down a spare set i have layin around mate i just ripped the ould system out..
thanks for the offer, but i only plan on using them until i get the rest of my system put in.
kl mate no bother..check that tho mitght be the problem ..i had a similar issue after doin mione..the rear ones would come on then go off when they wanted and it was a snapped wire i couldnt c.if your doin it properlay relay the whole cars sreaker widing mate mite take a few hours longer but well worth it.
