no spark on a valver
hi ive had probs with my clio thought it was fule pump relay as u can run it an it will be ok the it will cut owt wen at low reves then wont start done it 3 times an i called aa owt they cheacked it an theres no spark he recons it could be the crank shaft sender not sendin feed or thr module any one know if this is right or had same prob
So the cars not starting now???
Or does it start then die after a few seconds???
What does the dash signal???
Is it a phase 2 if so is your electrics light not flashing on the right hand side of the dash once the car has cut out??
My cars just back with me after 4 weeks off the road and it was the standard immob locked on...It would fire up then cut out after a few secs!!
It was lowloaded off to a few places but in the end Renault were the only people who were able to sort it for me!!
its the yelow wire that goes 2 the coil mate we found it last night that trigers the coil an the fule pump u can run the car by bypassin it at min by hard wirein it 2 the bat but car satys runin after started with key so need 2 find were that wire comes from
