noise under engine braking
Car  Clio 1.4 Ph2 Extreme
theres a noise developed on my clio, its a mk2 ph2 lowered 40mm and has done 35k
the noise is when for example coming up to a roundabout with light engine breaking and in town when for example in third, no throttle and is a knocking sound coming from the middle maybe right.
Ive jacked the car up and there is a slight side to side move in the wheel, when pushed and pulled alternately at say 9 and 3 oclock on the wheel. its only minor but makes a slight clicking sound. would this be in the rack? or the track rod end. but it sounds more speed related to me i.e the interval between clicks is faster at higher speed.
Any help would be much appreciated and also any common clio problems it could be
Thanks Liam
