Noisy dephaser pully
  172
How can you tell when it's on its way out ?
Ive just picked up an 04 182 and it's noisy on tick over like its low on oil and Tappety but rev it to 1300 rpm and it goes and sounds as quiet as a mouse
does this sound right or is it something else
i have just done my cambelt & dephaser on my 182 and now i have a real light tapping noise at idle that i never noticed before i did the work. it doesn't do it all the time. i need to have a listen in the engine bay when it does it but i think it might be the charcoal canister solenoid that i can hear at idle (when i'm not on idle the engine noise takes over/it stops and i can no longer hear any tapping noise) it might be worth just checking that before making any expensive commitments.
my engine was probably making the noise before i did the cambelt i just probably never noticed it.
when a dephaser is bad/going it usually sounds like a diesel from what i have read
  GSXR + KDX220
Rattley!! More so when its upto temp! Mine is pretty quiet when its first started in the morning.
  172
Yeah mine was quiet as a mouse this morning but sounded like it was low on oil by the time I got to work. It only does it on idle, rev it to 1300 rpm and it goes away
Any further thoughts
  182/RS2/ Turbo/Mk1
I cant see anyone having any thoughts other than "your dephasor has had it", what you are saying is a pretty much perfect description of what they go like.
Coops Mk1
  Lots of Scrap...
on a side note and whilst dephasers are under discussion, are they the same across all MK2 RS engines, phase 1 172, phase 2 and 182?
loggyboy
Check the fuel rail heat shield, i thought my dephaser was getting worse (is rattling anyway) but it was just being added to by a rattle from the heat shield! I ended up with a slightly less rattly Clio!
