Noisy/whining TPS/throttle body, is it normal?
Paddy_g46
As above really. With the ignition on, engine off, the throttle body is making a fairly loud noise/whine which doesn't sound healthy. Good or bad?
Patrick
edit: Oh and also, with ignition on, there is a sound that I can only describe as an old school printer going on around by the drivers side headlight, top mount location? really wierd....
  182 cup
Throttle body fault is down to the throttle body. Mine started doing it a few months back then all of a sudden it died!
Went upto nearly 3,000 rpm with no load then in gear it wouldnt rev past idle. Was very dangerous so I would recommend changing it ASAP.
Got mine from Cliospares - very quick delivery and a pleasure to deal with
Mike
  ITB'd MK1
they all make a noise to some extent, but some are louder than others.
The noise behind the headlight is the carbon canister solenoid
Paddy_g46
Cheers guys, I met up with a mate who has a 172cup earlier and his sounded exactly the same so im happy its ok now.
Why is the carbon canister going so mental?
