Non cup to cup 182
  Mk2 escort clio cup
hi all
I'm new to Clio ownership but I bite the bullet and bought what I believed to be a 182 cup (well that's what previous owner said )
The previous owner said that when he bought it the car was very low so changed the suspension and wheels the wheels are 172
He was mid 50s
Now I have been looking for a set of coilovers as I intend to do a lot of track days I saw from the forum that it should have 60 mm between the two hub bolts
This one has 54mm now I have a set of cup hubs I got local for £50 to use when I get my coilovers
My question is do I need anything else or will it bolt up
I have searched this forum for answers but doesn't really answer what I want
Cheers Jake
  PH2 172
hi all
He was mid 50s
Cheers Jake
AST 5100`s fit both 54 & 60mm hubs.
  PH2 172
But as I have the hubs will they bolt straight on?
Agreed in buying the best as your only buy once
The wishbones, subframe, ball joints, steering rack & track rod ends are all the same, though you will have to get the alignment done, as the steering arms on the 60mm hubs are slightly different.
The question I cannot answer is will you need to change the driveshafts?
What width are the ABS rings on the shafts you have, 7.5 or 15mm?
@bloke is the CV expert.
  Mk2 escort clio cup
When I picked up the hubs he gave me a set of new rings for a cup unsure of the width
Thanks for replying though
