thought they were around 800ish standard once warm.
I think the RS tuner remap raises it too around 1000
Even my cam'd car doesnt idle that high! mines around 1050 / 1150ish.
Have you checked for any vacuum leaks etc?
Oh is it a ph1 or ph2?
Could be the thermostats buggered if its staying at 1200rpm, as i think they stay on the cold map when the thermostats broken?
Does the temp needle not go to the middle when fully warm?
Also you tried ragging it when warm? as if the limiter kicks in at 6,800 i'd say your thermostat needs changing.
