not good on handling
Car  RenaultSport clio 172 mk2
ive put a set of 17" alloys on my 172 and dropped it 30mm all round but it still doesnt feel very good on handling on corners should it feel like this or could it be a rear shock thats on its way out? it feels like the cars on ice when turning into a bend it just feels very unstable i thought by dropping it 30mm this should make up for 17" rims ive put on it:dapprove:
i have falkens on at the moment i just cant commit 100% in to the bends it just isnt safe enough:dapprove: if i let go of the steering wheel it doesnt pull to the left so i think tracking is fine
Having tracking out cam do all sorts of things it might be bent.
jon 172 said:
what could be bent?? mate:D
Any number of things
Rear axle
Bottom ball joint.
Wishbone
Bushes (damaged that is not bend)
Top mounts
Stearing arm.
Stearing rack.
Subframe.
are the wheels balanced and what psi are you running they may be over inflated?
the girlfriends was like that! i drove it and hated it! just in the process of having a new rear axle fitted!! t'was bent apparently! fingers crossed all is well!
