Not starting first time.
mikeh
  182 Trophy
The 182 is idling a bit rough and quite often needing a second attempt to start each time.
I fitted one of the new blue crank sensors a couple of years back. I'm wondering what the chances are of that failing already or whether perhaps I just need to look at the joints on the replacement plug wires.
Any fool proof way to test?
  182
Will be watching this, having a similar problem at the moment, just had a new set of ngk plugs fitted ( didn't make a difference ).
I was thinking possibly coilpacks?
mikeh
  182 Trophy
Have you changed your crank sensor? If not, that's the first thing you need to do.
Cough up for the official Renault one that comes with a replacement plug. It's around £60 IIRC and solved my issues last time.
Thinking about it, it could probably do with a clean, if not I shall just re-do the connections where the new plug was joined.
