Not starting issue - Crankshaft sensor
Car  1.2 16v Black Stealth Rep
Hi guys, I recently had my crankshaft sensor replaced from eurocarparts, and im still having the same issues.
The car just cranks but doesnt start, once I move the sensor about the car starts, Isit still a fault with the sensor?
Help :(
Help :(
Sounds like it. Strange the new one does the same. Loose wiring on sensor connection maybe?
I think the current wiring is more likely to be the issue rather than the sensor you've replaced... the main reason why Renault issued a tech solution creating the new loom mentioned above.
New part will set you back around £60 from a dealer though the part(s) can be had from a decent autofactors for around £23... tell them you need the blue sensor with the new plug
