Not gonna be o2 sensor, check the easy stuff first - is there a wire loose? plug ok? then compression test to rule out internal damage. then coil pack, injector...
So I checked the rest of the stuff out and still have a slight miss on a single cylinder. I have also got an o2 fault on the second o2 sensor. Where are both the o2 sensors located? Would be much help
