OBDII scanner for phII 2004
Car  Clio II dci
Is there any cheap ones that read airbags/etc? I don't wanna spend tons of money i just wanna read some codes and clear airbags nothing fancy but i can't find any cheap ones... someone help?
Sent from my Redmi Note 5 Pro using Tapatalk
You'll struggle to find ones that will clear airbag codes.
The SRS system is self diagnosing and the light will go out when the problem is fixed, so chances are you'll have to fix the fault before you can clear the light anyway.
Where abouts are you?
The iCarsoft i907 will read most of the codes on these. They're about £90.
I'm in Portugal, the thing is the airbag light is on and it doesn't seem to be the cables on the seats becsuse they're soldered most of them.
Oh, i would have scanned it for you if you were local ?
Could try the Torque app with a cheap bluetooth OBD tool. Can't remember if Torque will read airbag ones or not, i think it does.
You need clip ideally. As above it will be in fault if the light is on for some reason as clears itself when correct.
