Odd misfire
Car  Gentlemans spec 200
Getting a strange misfire. Only happens when the cars very hot (most noticeable on track) and only under hard acceleration. Changed the plugs and leads, just ordered a coil-pack. Hopefully that'll sort it, but any other suggestions just in case?
Warren
Maybe coolant temp sensor but thats probably a long shot. Coilpack would be my first port of call TBH, then code read it if that doesn't solve it....
Right, leads, plugs and coil replaced. Still misfiring. Only intermittent, drove 2 hrs today without problem, then it started playing up again. Does the rs tuner function as a code reader?
possibly a load sensor, MAP would be my first thought.
I could be way off the mark, but heres my thinking anyway..... Missfire perhaps caused by lean mixture, hence load sensor, MAPs can be effected at high temperature dependant on type?
Edit: and RS tuner will read a fault if it's registering a fault.
Sticking injector ?
Piston rings ?
Maybe even some witchcraft with the alternator.
Check the injector seals on the injectors too.
Ok, done so far:
-New spark plugs
-New leads
-New MAP sensor
-New coil pack
-Cleaned earth points (except the one on the back of the gearbox, will do tomorrow)
-Changed all injectors
-Had code reader on, no faults registering
Still f**king misfiring! Happens when cold and hot. Changed the coil pack today, drove it hard all the way home. Faultless until I was nearly home, then misfired again.
Changing Lambda tomorrow, just in case. WTF else could be causing it?
after all that, i'd be inclined to wonder if it could be a wiring fault somewhere.
has the ecu ever been disconnected?
you are welcome to borrow any of the parts from my car if you want, could save you buying more bits that you don't need.
(although, borrow is the operative word ;))
Not that I know of. Was running like a peach, until the exhaust dropped out of it's mount at Oulton on the RS day.
Thanks for the offer. I'll most likely borrow the suspension and the new engine;)
Brown Bear; Thanks for the offer. I'll most likely borrow the suspension and the new engine;)[/quote said:
you need to fix the missfire first :rasp:
i had a similar thing where the clip for the cable to the tb was damaged, but that won't apply to you.
put it back on diagnostics and look at the mVolt readings for the lambda. pre-cat should cycle between 0 and 1000 (give or take, in reality is'a about 40-900) if it's not cycling, or not going full range the sensor is suspect. Wont normally pick up a code for that either
Good work. was it damaged at all? any evidance of the sensor hitting anything when the exhuast dropped?
Posted your stuff today BTW
The sensor looked reet, but the clip where it joins the loom is fucked, so there's obv been some trauma. Over 300miles done in last 24hrs, hasn't missed a beat.
Fingers crossed!
