odyssey battery, where is the cheapest place online?
Just wanted to know how much they can be had for coz ive been offered a supply of them. Trying to work out if I could do them cheap enough
If you do get some cheap Jay, put me down for one!! I want one but cannot justify the expense at the minute.
Mine is only a track car and sits on the drive for a week or two sometimes. Ive never had a problem with it. I have got an optimiser for it so if im going away for an extened time (had 4weeks not using it) then just plugged it in and it keeps it all topped up nicey.
its more of a poblem if you get the smaller ones.
Spec on these...........
[FONT=Verdana, Arial, sans-serif][FONT=Verdana, Arial, sans-serif]PC680 Odyssey battery Voltage: 12 v
PHCA 5 seconds (Pluse Current): 680
CCA: 220
HCA: 370
MCA: 300
Dimentions: 185mm Long X 79mm Wide X 170mm High
Weight : 7.0 Kg
[/FONT]
[/FONT]
Compairing the spec on these to the Odyssey/Redtop 25 they are identical, just different branding.
Heres pics of the one i have. Fits under the passenger seat lovely
[/FONT]
[/FONT]
Is the PC680 not an older model, which has been replaced with the 20/25/30 etc to stick with the Varley ratings? When is your battery dated?
My battery man said they were just the branding. As I said the spec is the same. I need to check when I see him later this week. Prices he has given me are very good tho
All made by the same people tho, loads of names for them. redtop, varley, odyssey, enersys, dms etc.
Will have to look at the date on mine when i get a chace, warrantied for 1 year anyway
So I'd probably be fine with one then. Might have to.
