Offence Code LE90
Overtaking in a Zebra Crossing!!. £60 fine but does this come with points? Anyone know? Also is this going to seriously affect my insurance?
Tom
  EV
try it (how?!!!!!!!!!do you overtake!!! in a zebra crossing) and find out....
"postman pat postman pat in his civic type r.."
Tom
  EV
Keith only kidding (sort of)
rob you could say your the son of god and you need to get to the second coming but they still gonna take £60 off you
  Astra 1.9cdti XP
tut tut!!! What were you doing overtaking on a zebra crossing?? Try to get home while the bread was warm!!! ;)
Normally crossing offences are all PC**. Never heard of an LE** offence.
Sure the code is right? PC normally carry 3 points.
Effect on insurance impossible to say till you tell them , all insurers different.
LE90 thats what it says in the ticket. He did not say anything about points but just to pay the fine and that would be it.
Impatience, some bloke was going slowly along the road (looking like he was going to stop at anytime) so after the crossing I overtook him, right in front of the Police which I did not see until I looked the rear view.
Naughty boy I know :oops:and I am willing to take the punishment but I am unsure if it comes with points.
GeordiePaul, you should know better. I have delivered all my bread by 8am!! Fresh is my middle name.
Keith
Was on the Zig Zag lines apparently and was going at quite. I dont think it was as bad as they made out but I was not going to argue to point at the time. I may consider going to court if there is points involved. The problem is that when excellerating at 20mph the car sounds like it is going a lot faster.
Not sure what to do? I am sure I would have to be past the zigs to overtake him but at the time you question yourself because you are put on the spot.
  Astra 1.9cdti XP
They pulled you over cos you have a fast car.....simple as that. They could have give you a bollocking and then let you go!!!
Conviction Code Description
AC10 Failing to stop and/or give particulars after an accident
AC20 Failing to give particulars or report accident within 24 hrs
AC30 Undefined accident offences
BA10 Driving while disqualification by order of the Court
BA20 Driving while disqualified as under age
BA30 Attempting to drive while disqualified by order of the Court
CD10 Driving without due care and attention
CD20 Driving without reasonable consideration for other road user
CD30 Driving without due care and attention or without reasonable consideration
CD40 Causing death - careless driving when unfit through drink
CD50 Causing death - careless driving when unfit through drugs
CD60 Causing death - careless driving with alcohol level above limit
CD70 Causing death - careless driving - failing to supply specimen
CU10 Using a vehicle with defective brakes
CU20 Using a vehicle with parts or accessories in dangerous condition
CU30 Using a vehicle with defective tyres
CU40 Using a vehicle with defective steering
CU50 Causing or likely to danger by reason of load or passengers
CU60 Undefined failure to comply with Construction and Use Regulations
DD10 Driving in a dangerous manner
DD20 Driving at a dangerous speed
DD30 Reckless driving (replaced by DD40 from 01/12/91)
DD40 Dangerous driving
DD50 Causing death by dangerous driving
DD60 Manslaughter or culpable homicide while driving a vehicle
DD70 Causing death by reckless driving (replaced by DD80 01/12/91)
DD80 Causing death by dangerous driving
DR10 Driving or attempting to drive with alcohol above limit
DR20 Driving or attempting to drive while unfit through drink/drugs
DR30 Driving or attempting to drive/refusing or failing to supply specimen
DR40 In charge of vehicle while alcohol level above limit
DR50 In charge of vehicle while unfit through drink or drugs
DR60 Failure to provide specimen for analysis other than driving
DR70 Failure to provide specimen for breath test
DR80 Failure or attempting to drive when unfit through drugs
DR90 In charge of a vehicle when unfit through drugs
IN10 Using a vehicle uninsured against third party risks
LC10 Driving without a licence (replaced by LC20 from 01/12/91)
LC20 Driving while under age. Driving other than in accordance
LC30 Driving after making a false declaration about fitness
LC40 Driving a vehicle having failed to notify a disability
LC50 Driving after a licence has been revoked or refused medical
MS10 Leaving a vehicle in a dangerous position
MS20 Unlawful pillion riding
MS30 Play street Offences
MS40 Driving with uncorrected defective eyesight or refusing test
MS50 Motor racing on the highway
MS60 Offences not covered by other codes
MS70 Driving with uncorrected defective eyesight
MS80 Refusing to submit to an eyesight test
MS90 Failure to give information as to identity of driver etc.
NE99 Non-endorsable criminal Act
MW10 Contravention of Special Roads Regulations (excluding speed)
PC10 Undefined Contravention of a Pedestrian Crossing Regulation
PC20 Contravention of Pedestrian Crossing Regulations - Moving vehicles
PC30 Contravention of Pedestrian Crossing Regulations - stationary vehicles
PL10 Driving without L plates
PL20 Not accompanied by a qualified person
PL30 Carrying a person not qualified
PL40 Drawing an unauthorised trailer
PL50 Undefined failure to comply with conditions of Provisional
S 19 Disqualification ("totting - up" procedure)
S 35 Disqualification ("totting-up" procedure)
SP10 Exceeding goods vehicle speed limits
SP20 Exceeding speed limit for type of vehicle (excluding goods)
SP30 Exceeding statutory speed limit on a public road
SP40 Exceeding passenger vehicle speed limit
SP50 Exceeding speed limit on a motorway
SP60 Undefined speed limit offence
TS10 Failing to comply with traffic light signals
TS20 Failing to comply with double white lines
TS30 Failing to comply with a Stop sign
TS40 Failing to comply with direction of a constable or warden
TS50 Failing to comply with traffic sigh (excluding stop, lights)
TS60 Failing to comply with a school crossing patrol sign
TS70 Undefined failure to comply with a traffic direction or sign
TT99 To signify disqualification under "totting-up" procedure
UT10 Taking and driving away without consent or attempt thereat
UT20 Stealing or attempting to steal a vehicle
UT30 Going equipped for stealing or taking a vehicle
UT40 Taking/driving/be carried in a vehicle without consent
UT50 Aggravated taking of a vehicle
XX99 To signify a disqualification under "totting-up" procedure
LE 90 is not listed , either wrong or a very new code
That take you a while to type? or was it a cut and paste job? lol
Wonder how many people on here have got/had a few of them, gto my 1st SP60 last year (bought a speed camera detector the next day).
For the fine I wouldnt bother arguing if it aint a points offence, if it is you aint really got much to loose, if the copper aint got u on camera etc then what evidence can they priduce? Was it one copper or two in the car? and was it a traffic car or a jumped up little prat in a sh!t box Fiesta? If it wasnt a traffic car or there was only one copper you should be able to get away with it
PS if the ticket has an error on it it doesnt stand either, request clarification from the police station of what offence it is and check for ANY mistake.
Tom
  EV
rubbish the one copper thing is bollox as for it being a traffic cop it dont matter- its an offence regardless of where it is
it is easier to argue that the perception of one copper can be slightly incorrect though the perception of two coppers is harder to argue against. It worked for me in court, and I was in the right then too (y)
  BMW 320d Sport
LOL @ Matthew, mine licence isnt quite as comprehensive -only a measly SP30 and TS10 to my name. Doesnt matter whether its points or not. Any ticket deserves to be challenged even if you did do it!
Looks like points. Took documents down to the station this morning. Unofrtunatley I did not have the paper part of the licence but she did mention I needed it to send off.
I think when I go back I will ask to clarify the offence code and ask how many points. It was a focus with 2 officers, I dont think they have any evidence (apart from the sound of the VTEC as I floored it) but such is life I will take what ever the outcome is.
I hope I can find the paper part, failure to produce makes things a little different:sick:
