I have a user who works from home a lot and roaming. I have offline files enabled on the company files.
She also uses Cisco VPN to connect to the Company Server when she's at home. When she gets back to the office normally she can sync fine (or over the VPN). However I'm getting a sync error:
"Unable to merge offline changes on \\server_name\share_name. The parameter is incorrect."
http://support.microsoft.com/kb/230738
I can fix the issue by wiping the cache and resetting up offine files but this is now the third time it's happened - seems ok for about 2 months then corrupts!
Any thoughts on what is causing the corruption? she does struggle with Excel documents being slow.
Other remote users who use the VPN have no problems.
