is it possible to get an offset of 25 to an offset of 37 using spacers? quick reply needed thanks
RuFF21 Civic Type -R FN2 Jun 16, 2006 #1 is it possible to get an offset of 25 to an offset of 37 using spacers? quick reply needed thanks
kiza1986 1.6 focus zetec.... Jun 16, 2006 #2 dont think so 'cos i think the spacers come in 5mm but im not 100% Kiza
Englebert Turbos. Jun 16, 2006 #4 FK Automotive do a range of them, from 15mm to 35mm. Renault Clio type: Bwidth per axle: 30 mm PCD: 4/100 thread: M12x1,5/S order number: FK13315BZ Renault Clio type: Bwidth per axle: 40 mm PCD: 4/100 thread: M12x1,5/S order number: FK13320BZ Renault Clio type: Bwidth per axle: 50 mm PCD: 4/100 thread: M12x1,5/S order number: FK13325Z Renault Clio type: Bwidth per axle: 6 mm PCD: 4/100 thread: M12x1,5/S order number: FK13330Z Renault Clio type: Bwidth per axle: 70 mm PCD: 4/100 thread: M12x1,5/S order number: FK13335Z
Englebert Turbos. Jun 16, 2006 #5 Wait a min, if you have ET25 the last thing you want is spacers! That means your wheel is sticking out.
M Michael Clio II and Grand Modus Jun 16, 2006 #6 You have to take something off the rim to come from et 25 to et 37. Spacers will get the rim further out the arch.
M Michael Clio II and Grand Modus Jun 16, 2006 #8 think 7 mm is a bit to much to cut away imo........sell the rims and get some that wil fit. Best solution but not cheap.
RuFF21 Civic Type -R FN2 Jun 16, 2006 #9 was planning to sell them anyway just wanted to try them on the car. think they would sell for more in an ofset like 35 is the thing Last edited: Jun 16, 2006
Englebert Turbos. Jun 16, 2006 #10 There is no one hardcore enough on here to buy them. Sounds like they are better suited to another manufacturer?
