offset?
offset is basically where the hub face of the wheel is in relation to the centre line on that wheel
ET40 means the hub face of the wheel is 40mm from the centre line
ET30 means its only 30mm from the centre line (hence the wheel sticks out further)
sweet cheers mate,cos my old wheels are et38, and the new ones ive jus ordered are et40,just wondered if they would be ok
Original wheels are often tucked in the fenders. If you want them to come out more for a flush look, just get something with a smaller offset
Sorry that i hijacked your thread but does anyone know the offset for the stock 2003 Clio Dynamic wheels????
is the offset of the stock ph1 172 ET.43?
So the point of using a spacer is to build up the distance to the same as the stock item?
Does that mean that you can then use the stock bolts/locking bolts too? if you don't use spacers do you need shorter bolts then?
Sorry to hijack thread!
