oil change
I have just purchased a Clio sport 1.2 16 valve, where is the oil filter! I have found out its a paper type and needs a 66mm/6 flute wrench to remove,I would like to know the location of the filter,do you need the wrench? and do you need a special tool for the sump plug.
Thanks in advance.
There three different types on the 1.2 have a search round.
8mm square sump nut for the plug though halfords etc sell them.
The filter is on the drivers side of the engine near the timeing belt, there should be some arch lining that sort of clips off. You should be able to remove it by hand.
