Yeah definitely Joe, Id go along with that, get an oil cooler if you need it, otherwise its not necessary. An overcooled engine is just as bad as an overheated one when youre giving it some stick. I drive mine hard and cruising at 125 on my private motorway test track, and B-road thrashing, trackdays especially, the oil would be up at 120+ sometimes up to 150 within a few minutes. Not good.
So mine has an oilstat built into the sandwich plate. That takes care of it and if the oil temp gets lower than 80, it closes the cooler circuit. In practice what it does is the engine warms up just as it usually does but then it just stays at the optimum temp of 90-100. Conveniently, the higher you rev the engine, the faster the oil is pumped through the cooler circuit. Just about as perfect a solution as you can get I reckon.
BTW Whoever it was who wanted the contact details for Think, just look on the members discount page. It should be there! And if youre not a Cliosport member its about time you were.
