Oil coolers: where do people mount them?
  ph1 track weapon
Looking atgetting an oil cooler and have an idea of a slightly different mounting point
For those of you that have them, where are they mounted and how do they hold up to road use?
Also how many rows would be sufficient for a Clio?
  ITB'd MK1
normally mount on the bumper iron, hung from underneath. Any more than 13 row is overkill. I'd more likely spec a 10 row. removing the undertray makes a noticable difference to oil temperature on track, I'd do that first.
If you still think you need a cooler then you must 100% use a thermostatic sandwich plate or your oil will never get up to correct working temperature
