Oil filter location - 1.2 16v
Rich-D
Car  E90 LCI 330d
My mate wants to do the oil & filter on his GFs car, but doesnt know where the oil filter is located.
The car is an 02 Reg 1.2 16v Dynamique.
The filter is prob easiest to remove by removing the front drivers wheel if using a jack. Its located just above the front right drive shaft. Its a black plastic filter.
it on the rear off the engine block.you can see it from underneath its just above the subframe.it will either be the normal metal filter or will be a plastic housing(unscrews the same)with a replacable yellow carboard cartridge inside(obviously not cardoard but thats what it looks like)
