oil leak and No 4 plug hole full of rust?
  182/Bora V5/S1 RS Turbo
Hi all.My 182 although being low milage at 24k has had an oil leak from cam box....or so everyone thinks. ive cleaned it all off and done about 1000 miles and its leaking from 4 of the bolts holding down the cam carrier.Off with the inlet manifold and find No 4 plug hole full of rust too. anyway removed every bolt one by one put a sliver of vw spec sealer under each bolt head and re torqued-job done(new inlet gasket and O ring coming from renault). why does it have water in No4 plug hole?? and while im there im gonna replace the plugs. anyone know the correct ngk or bosch part number?
  BMW M135i
The leaking bolts want removing one by one and sealing, and hope that sorts it. Otherwise its probably not worth sorting unless its leaking a lot of oil.
Rust down the plug hole is probably from moisture from when its been steam cleaned at some point :dead:.
