oil leak help
Car  1.2 2003 clio
Hiya just looking for a bit of help / advice . I have the 1.2 16v d4f engine and have a bad oil leak on the rear left of the engine not 100% sure exactly where tho. When I changed the rocker cover to try solve the issue I came across a snapped bolt which is on the left directly under where the coil pack sits which looks to be just another rocker cover bolt. The head is no where to be seen so gonna have to attempt to get it out which I'm looking forward to......Not.
So basically is this likely to be the source of my leak and does this bolt hold anything else as well as the cover down?? Oh and any suggestions on where I could get a new bolt from??
Cheers in advance for any help.
