Oil leak
Hi all
Ive got a very slight oil leak on my car. Its no that bad as it doesnt drip at all, its just the bottom of the engine is really covered. I was wondering if this could be related to having problems getting into 1st and 2nd gear? I heard it could be oil leaking onto the clutch plates from somewhere causing them to stick??
Any advice or areas to look at appreciated.
Dazz
cam cover, its probably loose. Get a new gasket and tighten it properly then clean the engine.
The go for a nice drive to the coast or something and back then have a look for leaks. If there are none then magic, if there is you should be able to pin point it easily on a clean engine.
