Westfield, 182, 200
I took my 182 for an MOT today (failed on number plate lamp and windscrenwashers not working :banghead: luckily, it's a friends garage and I sorted it whilst I was there) and found an oil leak.
I took the undertray off and wiped the are down, but can't see where the leak is coming from! It's not from the head but it's wet around the gear linkage and the left hand drive shaft-it also seems to collect around the sump area.
Are there common leaks on the Clio around this area??
Cheers, Ian.
Cheers, Ian.
