"Navy" N17 TWO
Earlier in the year I was topping up about 900ml in around 650 miles - the dash is always wrong!
If the car is parked with the front facing uphill - the dash throws on the SERV light & flashes oil ------
When I check the dipstick at regular intervals I get different readings.....on the same day!
Sometimes when I check it hot, the oil is over the max line
Brand new oil level sensor fitted when the last oil change was done - thought it worked - must be placebo
Any mechanic I've ever asked has never heard of a compression test :S even Renault!
Any ideas?
Any ideas?
