oil light
Car  clio sport 172, 2002
my oil light keeps cuming on now along with the stop light, i have toped up the oil, but its still cuming on,
any ideas ????
I had this problem a month ago :( The car was runing fine when cold, whean it warmed up the oil and stop light was coming up, when reving over 1500rpm it goes out. I was thinking the oil was to thin (previously elf 5W30) filed up with a thicker oil 10W60 and the car was running fine. But when it got to the cambelt change few days ago, I told the mechanic to fit the new cams I bought form CatCams.
When they opened the cylinder head, the cam bearing journals were totally worn off :/ since I was not able to find the head alone in good price the only way was to find a new engine.
I would consider the possibility You car is suffering the same
One way or the other, go find some garage with oil pressure tester and check the real oil pressure. It might be something electrical or oil pressure sender itself, but it needs to be checked
yeah will do mate thanks for your help
