Oil pressure shooting up
robmunns
Car  Ph1 172
Cars fitted with an auto gauge pressure gauge (s**t I know) but the oil pressure seems to jump at around 4.5k revs
Should this be happening or not?
Also quite a big misfire after changing to 4th under load.. Cars boosted on an adaptronic ecu so what's best to look at first?
I mean, assuming the gauge is not faulty and that it's fit correctly, you'd still want to get the car on diagnostics before guessing what's wrong.
You say it's a turbo 172 as well? Who built it, did you buy it like that?
The cars running an adaptronic ecu so diagnostics isn't really that easy, guessing I can log what the ecu is seeing and give that to efi and see what they think (they mapped it)
The car was done by Clio turbo about a year ago
