'Oil Pressure too low' warning.
Coby.
Car  XC60-R.......V40-R
Its not a Clio but hoping some mechanically educated folks may be able to help, my '07 207 HDi decided to flash this up as I was driving home tonight, kept going on and off so may be intermittent fault so hoping may just be a dodgy connection on a sensor or something.
I'll check the oil level in the morning but if that's all good any suggestions on what to check/replace next?
Car has covered 120k miles if that makes any difference on what could be up with it.
Thanks in advance.
Thanks in advance.
Rather than join in a guessing game, get one these connected.
https://www.ebay.co.uk/itm/UK-Wave-...033471?hash=item2ed1c7e2bf:g:wgEAAOSw1BlZUVXb
It would have been quicker to check the low oil warning that you own than post this thread.
Its not a low oil warning, its pressure and doing some googling through up many possibilities.
Checked the oil level and it seems fine.
When was it last serviced?
It had a major service last March but has spent a lot of time in the garage the past 6 months getting all sorts of faults sorted.
Apparently the oil was full of soot and cheap which has damaged the bearings, they've flushed the oil but reckon the damage is done.
Going to see if the Gf's Dad thinks he can swap the engine if not run it until it completely fails I guess.
I'm really not a fan of oil flush mate, I'm a great believer in buy a good quality oil and change it regularly.
Adding a oil flush can sometimes cause more problems than its worth, it can dislodge particles that can block oil ways.
