Fred is right so listen to what he's telling you and forget the sprockets key way (I believe its the same oil pump and sprocket used on the Megane F7R-714). Its purely bolt tension and clamping force that holds this entire assembly together which works just fine.
Till someone doesn't tighten it properly or it decides to come loose lol Aint going to slip if its running a keyed cog.
I'm going 225 meggy for slightly more peace of mind with this rebuild
Not sure why Renault didn't keyway it. I know Ford Zetecs in 2 litre form are
Wont make a bit of difference, it won't stop the timing slipping or the oil pump for that case if the bolt loosens. The only benefit it has is on a supercharged engine where the pulley is being used to drive something non oem.
If the bolt comes loose it can't slip, thats the whole point of keyway. The lug of the cog slots into the crank preventing it ever being able to turn independent of the crank hence why they fit them on charged engines.
The key won't last any length of time if the bolt comes loose anyway, believe me as a mechanical engineer. Also, if that does happen you'd be lucky if it didn't ruin the shaft as well.
Which is y I asked the question in the first place. Thanks for the info, maybe it's just the way I read the reply from micK but it seems a little touchy I maybe new to posting on here an to the Mk2 engine But im no stranger to the clio Mk1 iv built many engines, an many people off clio16v have had parts an wanted me to diagnose there issues with there's, yes I understand Now that rick is a guy in the no about there's engines an more. So calm it.
Yeah all it does is stop the crank aux pulley from spinning, there are three pieces that attach to the Clio F4r crank on the timing belt side, 4 if you include the bolt.
Oil pump gear, timing belt gear and then the auxiliary pulley which is the only one that will be stopped from spinning by the key way. The other two are still held by friction the same as without the meg pulley. Best to use a megane crank bolt too (thick washer) as its a non stretch bolt.
I'm meaning the timing belt gear mate, the inner cog which the cambelt goes round. Thats definitely keyway'd on the Meggy 225 cog so can't slip.
The auxiliary pulley, i was led to believe the Clio 172 / 182's where the same as the Megane 225, held by the bolt not key'd?
Basically it would have to undo completely before it gets expensive if you have the keyway one. Has anyone got the part number for the keyway one?
My understanding is the opposite from yours as the 'inner cog' needs to move in order to time the engine with any accuracy (it does on the clio's anyway) The aux pulley is what you wanted keyed for a supercharger as that is what's driving it.
The power in an engine comes from the pistons through the crankshaft, I would agree a keyed 'inner cog' would be of be benefit if the power came from the camshafts which would then be putting power (drive) through the belt itself.
Edit: Just seen your pic post. Its definately keyed but I don't see the benefit of using it??
Never timed a Clio but the Ford Zetec engine has a keyway and all i did was put the cambelt round the bottom cog, slacken off the cam pulleys till the belt was in position then lock it up and tighten the bolts. Would imagine the Clio would be the same?
The Meggy 225 benefit is, the cog can't move if the crank bolt becomes slack, it can if its normal 172 / 182.
Is the Megane auxiliary pulley, the big outter one, keyway'd ?
the aux crank pulley isn't keyed on any F4R
A Keyed crank pulley would not save the timing from slipping if the bolt came loose. The key ways are literally there as a locating tool.
Whats the point in changing to a 225 cog when using a s/charger if it still spins? Its keyway'd thus can't slip independent of the crank, thats the whole point :S
Chip I still don't see how this has any affect on stopping a supercharged engine slip the timing when all the extra load is put through the aux pulley. If the aux pulley was keyed I would see a benefit, if the crank sprocket moves then its game over anyway as you have just said above with it having intertia to break the woodruf key.
Also if you think about it the engine turns clock wise from timing belt side (iirc) so it would actually be tightening the bolt when/if for any reason the charger had more drag put on it.
The engine turns clockwise, thus the drag is then anti clockwise.
