thanks for that most helpfulI was going to say no but having looked at it again it's more evident than first appearedView attachment 145731
This is mine, couldn't get a beeter photo as the mrs car was sat in front and I was too lazy to move it first.
I did indeed use 8mm bolts, I tried 10's first but it's all a little too tight and didn't sit square on the floorpan so I opted for 8's which give a bit of movement to set things up, once tightened they haven't moved at all
eon172 could you let me know how thick the alloy bar you used is ... looks like I will be needing some !!!!!
I have the OMP ones as above , these look to be a lot taller ......perhaps some one will shout if they have themAnyone tried one of these? I'm 6ft+ and require something low set...
http://www.sportseats4u.co.uk/brand...t-lowered-direct-fit-subframes/prod_1318.html
I have OMP and will be fitting them this weekend, I have offered them up and it don't look to bad but it's dark so will let you know more on Saturday, mine will be level what ever it takes !!!I thought that but reading the description it says " directly into your lowered Renault" What difference does it make if the car is lowered...confused!
The OMP looks the lowest but really cant be arsed with fettling with it to get it level, its supposed to be a direct fit..
Sounds good ,I have the OMP subframes and just used the Renault spacers on the tunnel side and mine are level, height is not too bad but I have modified my Bimarco aluminium side mounts and now this is as low as I can get my seat any lower and it would be touching the subframe.
My VBD subframes for the Clio give you the lowest possible seating position.Anyone tried one of these? I'm 6ft+ and require something low set...
Rig-up as f**k but we used washers on the inside of the seat frame to try and level the seats, to me their not perfect but they don't look like they're pointing inwards lol.
