one for the suspension guru's?
Car  F4R'd ITB'd '92 cup racer
or anyone else that can help me......
am i right in thinking that increasing the negative camber angle will give more grip on turn in?
the mk1 seems to be suffering with a wayward rear end, there is oodles of front end grip on turn in and it is VERY responsive and direct, however it constantly feels like it is 'dragging' the back end round and will snap out without any real warning
basically i am trying to gain a more balanced feel of over/under steer, at the min there is zero understeer (well, from driving as fast as is legal on the roads, but even in the wet it hasn't understeered once) and yet the back end feels very loose and has stepped out at some worryingly low speeds in the wet
so my question is, will reducing the front camber (say from -2.5 to -1 degree) reduce turn in grip, making the back feel more planted (providing i am not throwing it around)
Id say the best person to answer your question is 480bhp.com (Chris).
He knows so much about this stuff its unreal. My 182 was under steering a little and he told me to raise the rear a touch and it sorted it out. Sorry I can't be any more help but it will be worth PM-ing him maybe.
Try making the rear a little a softer, then go for a test drive and see what its like. Keep getting it a little bit softer until it feels like possibly going to understeer and then wind back quarter turn/two clicks
If it's as bad as you say, i'd check the rear toe, sounds like it could be toeing out.
There's loads more to check/change but until you've had the car aligned you can't rule out the obvious.
Chris
the rears arent adjustable, they are decarbon fixed rate dampers from the cup race cars
is it possible that you're bottoming out your rear dampers, or hitting a bumpstop?
im not sure if anyone has messed with the ride height, it does look pretty much the same height as every other original cup race car i have seen though
Chris
right i will get it aligned and see what's what
