One touch Windows help
MadUsa1
Car  Clio 200 Black and White
Is it possible to fit one touch window switches to both front windows?
I have a Swiss Trophy and neither of my front windows are one touch, which can be a bit of a pain.
What parts will I need for this?
Is there a how-to guide?
Thats strange, iirc all clios driver window switch's are one touch? - i want to go to the scrappy and take the driver side one off a 172 and a 182 amnd fit them to both passenger switches, then they would all be one touch,
Just an idea, not sure if it would work, dont see why not.
Think I remember reading in Haynes or somewhere that it's just a relay on the panel in the passenger footwell? Could be wrong.
start car. put window up then hold the switch up for 20 secs then put window down and hold switch down for 20 secs. resets the system.;)
Not that easy mate, the double switch on the drivers door is a whole unit, on the passenger door is just a single switch.
So the drivers one won't fit in the passenger side. :(
There is also something different about the relay somewhere along the line too IIRC
I understood the one touch windows were computer controlled and could be programmed at the dealers?
nope, doesn't work even if the engine is running.
If you have a RHD 1*2 you could easily get the one touch mechanism from a LHD driver's side and use it in your passenger side.
Has anyone converted a non-one touch to a one touch?
