Opening TCP ports
Clart
How can i open a specific port (9100) to allow communications through it?
If i used netstat -a, i can see that the required port is not active. I've tried going through windows firewall exceptions without success.
  182
Depends on your connection. If your using an internet router you will have to do it on there.
Clart
Its nothing to do with the router. The port was open, I install a microsoft patch, and now the port is blocked.
Clart
  Better than yours. C*nt.
And the post reply button is stuck!
Urm. Does the Firewall configuration not let you open it?
Clart
The windows firewall is disabled as default on our desktop. I've put an exception in (not sure whether it looks at these if the firewall is disabled?) but its still not showing as open.
  182
seems odd if the firewall is turned off and the port is open on the router. Uninstall the patch see if it makes a diff?
Clart
works ok if the patch is uninstalled, however its a corporate requirement to have it installed. DOH
