Outlook help
Car  Clio 182 cup'd
Basically at work I use Outlook 2000, I receive emails straight to the Inbox. I then have several sub folders for different things.
Does anyone know if it is possible to set certain incoming emails to go straight to certain sub folders?
Regards
you can create a rule to move certain mails, for example mails from a certain person. Have a look in tools, rules and then run through the wizard.
Yes. Its called creating a rule. The easiest was would be to right click on one of the emails that you have received and want to go into a specific folder - rick click and click create rule. Then just use the tick box to put into a specific folder.
