172 Ph2
Hi All,
Had my first outing in my newly acquired Ph2 172 (non-cup) at Brands on Monday and had a great day in the car but now have a list of things to tinker with.
The most notable issue was over-active ABS when trail braking in to a corner. In a straight line through a bumpy braking zone, pretty much no matter how much pedal force was applied I couldn't get the ABS to activate. However as soon as you turned in and carried the brake towards the apex, even with very moderate to light brake pressure (as you roll off the brake towards the apex) the ABS would kick in, you'd lose front braking force, weight would come off the front of the car and you'd sail past the corner if you weren't expecting it,
My initial thoughts are that as the inside rear wheel is off the ground on the way in to the corner, any light braking force is going to be able to stop this wheel from spinning at which point the ABS assumes you've locked up and kicks in.
I've read loads of threads on here about what's required to remove the ABS and install a bias valve but with the speedo stopping working I'm not too keen. Couldn't find any info on anyone installing a bias valve whilst retaining the ABS?
The car is running standard calipers, Brembo HC disks all round, DS3000s up front and PBS pads at the rear. Car weighs 950kg without driver, running BC DS coilovers, and AR1s. Road legal car used predominately for track days.
Would be interested to hear other people's thoughts. Thanks!
