Over cooling?
Car  1.8 RSi MK1 Superchipped
ok had a leak in the rad of my M95 RSi, that a water leak not the vegtable. fixed that with some rad weld, but now it seems to not run too hot, even the heaters on hot seem a bit cool....
is this just cos of the cold weather? just dont seem right.......
Tried beeding the system, and the levels are all good. anything else?
but the temp level does rise and fall, i.e. when i just sit on the drive it can get to about half way etc but once istart driving it goes all cold again :S
Ive been having exactly the same problem with my 94L RSI,( warm air and temp up and down) i took it to garage today and they found two of the pipes coming from the rad were perished.......so its booked in for Tuesday as they have to order parts...... surpise surpise
I`ve only had the car for two months and so far its had..........
NEW CLUTCH
RE-CON GEARBOX
NEW EXHAUST DOWN PIPE AND TWO BACK BOXES
NEW BEARINGS X2
Just the rear brakes now, as they are whistling and the pipes problem..
Then its fingers crossed :rasp:
