over heating
  E92 M3
my mates got an old clio (not sure the year but its a Mk1) and its been sat there for about a year and a half and its now back on the road but its over heating after a few miles
as it doesnt hav a guade so its hard to tell how hot it is but the light goes on and the fan kickes in some times
i said the mite be rust in the inside of the rad but i dont know much
any advice would be much appericated
  E92 M3
i have just spoke to him and he say that he emptied the rad flused it out and then filled in back up with water
He shouldnt just be filling back up with water. Needs coolant added to it. There is a coolant bottle towards the back of the engine bay, if he has filled it at the rad then it wont have anywhere near enough fluid in the system so he will need to top it up. Also check the engine bay for white marks as it probably has a coolant leak.
-KarL-
he needs to top it up here says on the side the min/max levels..
  E92 M3
yer i know i have filed mine up but i have never seen his tbh i dont think it has anything to do with the level
Water will work, but adding coolant to it makes it work a hell of a lot better. If he hasn't topped it up in that bottle and just filled it at the rad I would put money on it not having enough in the system. As I said previously, it probably also has a leak if it was overheating before hand.
  2005 Nissan Navara
Water on its own wont make it overheat.
The thermostat is probably fubared, and not opening.
I'd fluch the cooling system while your at it.
  2005 Nissan Navara
put it in some boiling water and see if it opens.
or for the sake of a couple of quid, just bung a new one in.
