P0130 - Powertrain Fault Code - Clio 200
Car  Clio RS 200 GW FF
I was driving this morning and my service light came on saying "Check emissions". When I got to work I plugged my OBD scanner in and the following code came up:
P0130 - Powertrain
02 Sensor Circuit (Bank 1 Sensor 1)
I cleared the fault code but it came back up, leading me to believe there's an actual issue. After googling the code it appears to be related to the Lambda Sensor Pre-Cat
Is it the same fitments as the one Post-Cat? Was thinking of swapping them to locate the problem.
Has anyone else ever had this?
Any help would be appreciated
Thanks in advance
Dan
Had that code and issue with my 182. Car ran fine but the emissions light kept coming on with that code. Changed the pre-cat sensor for a new one and haven't had an issue since. Think it was maybe that the heated part of the sensor had failed so would flag up a fault when started up first thing in the morning
Cheers BLT.
Im going to swap them at the weekend to see if its the sensor or not. Hopefully it is, £52 for a new Bosch one at Eurocarparts :)
Will use "Lastchance30" at the checkout for 30% off :P
