P0135 - Is this pre or post cat?
Car  172 Cup
Hi Guys,
Finally fixed the last CEL by changing an injector..... and two days later it has come back on with a new problem, yay cars! This time is is moaning about P0135 - Sensor Heater Circuit (Bank 1, Sensor 1), so it looks like I need a new lambda sensor. Question I have, from this code, do you know if this is the pre or post cat one?
As for doing the job, I've not done it on a 172 before, but I presume its a case of jack it up, whack it on some axel stands, swear a lot as there is probably no room to get a spanner, use the force to somehow get it out, whack a new one in, reset the code, job done?
Final question, Euro have a few options.... the Bosch one (I think that Renault fit?) for £65 or a HAAS one for £37. Any reason to justify the extra for the Bosch one other than the fact its OEM?
Thanks,
Will
It's probably worth changing both mate.
I had my post cat lamda changed and a week later the post one failed.
And from what I'm told don't waste money on the cheaper one. Go for the Bosch one.
