3 types you may use
cellulose
2k
plastic
cellulose is mixed with thinners, ratio is on the tin, usually about 4:1. i use this for primering things like small filler work, scratches, small things. has decent enough filling potential and dries very fast (solvent evaporation) (30 minutes)
2k is mixed with hardener and a bit of thinners sometimes, ratio is on the tin, between 4:1 and 5:1 with 2k hardener and 10% thinners. very good covering potential, i use this for all my main filler work, all big repairs. takes a couple hours to dry properly, less if you apply heat.
plastic primer is used on plastic parts like bumpers etc. plastic primer out the spray gun dont need to be sanded down, its basically a wet on wet with the basecoat, just promotes addhesion, reduces risk of flaking
