I want to run PAS or electric steering on my mk1 f4r, I've been told the hard pipes on the valver rack will get in the way of the downpipe, sooo I wanted to know if anyone else had managed to keep pas or use leccy steering on a mk1 f4r
if you go the electric route I have a Corsa C variable Column from a low mileage 2005 car, and a manual controller I bought from a guy that makes them in Ireland, it plugs in to the port where the speed sensor would go, and has a control you mount in the dash somewhere, and you can dial in the amount of assistance you want, I bought it to fit to a Peugeot 205, for road rallying, but ended up selling the car again as it needed to much work. Cheers Chris
No need to use a corsa c one mate. You can use the Clio dci one which bolts straight in ( I've installed it in my car - so I 100% know) and you can buy a control box for it off eBay.
Saves having to fabricate mounts to fit the corsa c column.
